MitchF150 wrote:
There is no 'answer' to this one... I bought my Fleetwood RV TT back in 2002 and found out they were the worst manufacturer of the time..
Well, I still own that same TT to this day and it's been great.. Sure, there was some stuff to fix, deal with, but no all out failures of any system and no leaks of any kind, and just a good ol' rig for the last 15 years...
Sure, I have done all the maintenance, repairs and upkeep and such myself, and it's just not a deal where you just buy it and forget it...
You gotta maintain it and you gotta take ownership of it and you gotta deal with maintenance stuff and fix stuff along the way... Do you own a house? Pretty much the same thing..
Ain't no rig out there that is just gonna be perfect from day one and be the same way 10 years later without some work in between.
I've looked at lots of rigs since 2002 and all they have done is increase in price... And still require the same amount of maintenance and upkeep..
Guess that's why I still have my first RV I ever bought... :)
Good luck..
Mitch
IMO you hit the nail on the head ... taking ownership and keeping up with maintenance is the key. Sure things need to be replaced, but that is just how it is over the long haul. My last trailer was a cheapo 1981 Fleetwood Prowler that I bought in 1982 and traded it in in 2007 on my current trailer. That's 25 years of ownership. When I traded it in there was absolutely nothing wrong with it and we still miss it. The SINGLE REASON we moved on was back in 1999 Va has a devastating hail storm that "dimpled" two sides and the roof of my Prowler. No penetration, but it looked more like a golf ball gone bad and the cost to fix was prohibitive so we lived with it and finally after another almost 10 years finally just wanted something that looked better and we found one we like so we traded in the Prowler (got $1500 sight unseen ... we bought it in 1982 for $6,000!).
During that 25 years of ownership besides the normal tires and brakes we did fol major items to it.
1. New refer around 1995 when old one finally went south
2. New water pump and redid plumbing to replace the old grey piping with state of the are at the time CVPC piping adding some extra isolation and drain valves.
3. Cleaned the furnace like twice (removed to get access), but the original was still there in 2007
4. Finally replaced the Suburban water heater around 2000 which I never serviced the anode rod since 1982. When replaced it was still working, but I had bought a spare back in the mid 90's because I anticipated it would need to be replaced and just finally got tired of carrying around that bulky "spare".
5. Did one major interior redo which was aimed at new foam, and cushions along with new carpet back in 2000 using the paltry settlement when the trailer was basically totalled by the insurance company from the hail storm in 99.
6. I also had to replace two spring packs due to breakage and I redid the suspension to wet bolts in the mid 90's and these two along with the refer quitting were the only "THREE" actual "EQUIPMENT FAILURES" besides like 3 or 4 flats during my 25 years of ownership ... a pretty good record IMO for a cheap, run of the mill trailer.
Larry
