msiminoff
Feb 09, 2016Explorer II
Hemi Joel wrote:
Would this package (ebay link below) work with my truck camper? Do I need some kind of cables to hook everything together?
Hi Joel,
That is the right antenna (NanoStattion), but it doesn't include the access point (airGateway)... Be sure you get both. In addition, you will need 2 cat5 ethernet cables. I used a 3-footer and a 25' flat one to sneak through an open window.
Daveyuhas- You can always do a software reset if you can't access the reset button... although I have yet to need to reset mine.
Naio- Interesting, but this thread is about wifi connections... not cellular.
hedge wrote:
?..it seems to me that he has essentially a router behind a router which will result in double nat'ing the traffic. Will work fine with normal browsing but you'd be unable to do an port forwarding or UPNP required by games or such. It seems to me you should be able to just set the m2 as an AP..
Although I haven't tried, I do think that the NanoStation can be used as a PtP connection to avoid the double-nat'ing. The benefit of adding the ($20) airGateway is that it gives me a secure wireless network for all of my devices.
Cheers,
Mark
