Flashman
Aug 16, 2016Explorer II
Careful - having flat towed toads over 60,000, miles I know a little about this - with many vehicles you cannot simply put the transfer case in neutral - many have to be started and ran every 200 miles or so.
The output shaft bearings of most transfer cases will not get lubed if the rest of the gears are not spinning. Jeeps are made to flat tow without running the drive train. But jeeps cannot tow shite.
Another thing to consider is making sure the steering wheel is not locked - If you have the key turned on - there goes the battery charge. Again Jeeps have a key position to unlock the steering and not turning on power.
44,056 PostsLatest Activity: May 04, 2014
