DWeikert
Jul 12, 2013Explorer II
skipro3 wrote:
Your suspension doesn't just 'fall' by gravity though...
It's pushed by the stored energy of the compressed spring. Ever see how much energy a spring that's been compressed a few inches by a ton when it's released. Moves pretty fast!!
By your description, the tire is airborne and SLAMS into the next washboard bump; a very harsh ride indeed!!!
I race off road motorcycles and have spent a lot of time with suspension in washboard conditions. I can tune a shock so the bike rider isn't even aware that he's traveling over anything more uneven than asphalt paving while the washboard is up to 10" deep. (13" of suspension travel in the shock.) Smooth as silk. Even more; there's not only compression and rebound on damping, there's high speed and low speed damping. Wash board is low speed; where the ground transitions fairly smoothly in rolling ground. High speed damping is with an abrupt edge. Like maybe hitting a curb head-on at speed.
Then there is damping for the various area of the shock's piston stroke; initial / mid and end of the stroke. This allows a shock to have stiffer damping as the shock piston is moved through it's stroke.
Shock engineering is quite a science.
I see your point and agree, to a point. It's a balancing act. Those shocks you tuned to ride comfortably on a 10" deep washboard would probably give a terrible ride on a 3" washboard with a different spacing. I still believe my explanation of the tire basically flying between bumps is why speed smooths out the washboard. The trick is finding the right speed for the particular washboard.
44,071 PostsLatest Activity: Aug 30, 2026
