ShinerBock wrote:
NRALIFR wrote:
The 7.3L gas option is $1705, and the 6.7L diesel option is $10,495.
That gets my attention.
Yes, but 100k miles and 5 years later, the trade in value plus the fuel mileage will pay for most(if not all) the $10,495 so you are essentially adding power for free. That will not be the case with the 7.3L over the 6.2L unless it has much better fuel economy. You only typically get around 70-80% of your money back from optional items such as engines, 4wd, and trim packages on trade in/resale. If the 7.3L uses more fuel, then that cost increases overtime.
There is also the case of maintenance if it is like the 5.7L and 6.4L in the Ram. Because of the special oil required due to the 6.4L having MDS, it makes maintenance cost a lot more than the 5.7L and more inline with what is cost with the Cummins for both fuel/oil filter changes.
However, my comment was based on the reasoning used by gaser owners who say they do not "need" more power. If this were true, then they would not "need" a 7.3L.
I'd like more power but I don't need 400HP and 1000TQ @ $10,495.
