librty02 wrote:
ShinerBock wrote:
goducks10 wrote:
ShinerBock wrote:
NRALIFR wrote:
The 7.3L gas option is $1705, and the 6.7L diesel option is $10,495.
That gets my attention.
Yes, but 100k miles and 5 years later, the trade in value plus the fuel mileage will pay for most(if not all) the $10,495 so you are essentially adding power for free. That will not be the case with the 7.3L over the 6.2L unless it has much better fuel economy. You only typically get around 70-80% of your money back from optional items such as engines, 4wd, and trim packages on trade in/resale. If the 7.3L uses more fuel, then that cost increases overtime.
There is also the case of maintenance if it is like the 5.7L and 6.4L in the Ram. Because of the special oil required due to the 6.4L having MDS, it makes maintenance cost a lot more than the 5.7L and more inline with what is cost with the Cummins for both fuel/oil filter changes.
However, my comment was based on the reasoning used by gaser owners who say they do not "need" more power. If this were true, then they would not "need" a 7.3L.
I'd like more power but I don't need 400HP and 1000TQ @ $10,495.
So you are saying that you don't need 400hp(even though it is 475 hp), but you like the 430 hp that the 7.3L makes? That does not make sense.
Also, I would bet you that uf you actually did the math with resale/trad in, the difference between the two is less than $2k over the course of 5 years and 100k miles. In fact, you are likely to spend more on the 6.2L to the 7.3L upgrade than you would with the 7.3L to 6.7L upgrade when all things are considered.
So I went and did a 5 yr 60000 miles cost analysis.
Diesel at 3.29 per gallon
Gas at 2.69 per gallon
Over the 5 yrs 60k Diesel will cost $1200 more due to DEF
5yr loan 60k diesel costs 66283 with 6% tax and 3.99% interest
5yr loan 48.9k gas costs 53993 with 6% tax and 3.99% interest
Diesel is 12290 more
Trade in Values for a 2015 Ford F-350 Lariat Crew Diesel vs Gas all same exact options but 6.7 diesel and engine block heater with 60000 miles on them
Diesel trade value 35490
Gas trade value 28427
Diesel worth 7487 more....7063 + 6% trade tax advantage
Diesel upfront cost of 12300 - 7487 = 4813 + 1200(fuel)= 6013 more to own a Diesel over that 5 yr period over the same gas truck.
No maintenance in these figures at all just straight cost of loan tax and fuel
As I said before, it depends on brand and regional prices. I did the same analysis, but for Ram since I bought a Cummins. I also used 1.95% financing because that is what i got through my bank. As you can see, the cheapest for me would have been the 5.7L gas, followed by the Cummins and then the 6.4L.
The fuel cost was also the average for the year since spread between the two is higher in the winter than the summer due to diesel being used as heating fuel in the winter making it cost more and gasoline not needing EPA mandated additive like it does in the summer to keep it from evaporating so quickly making it cost less in the winter. During the winter(5 months), it is about a 50 cent difference and during the summer(7 months) it is about a 30 cent difference.
Also, my truck is tuned and I average 17 mpg(hand calculated) even with 35 inch off road tires and driving 75 mph on the highways.
