Camper_Jeff___K's avatar
Oct 29, 2017
The Truck Camper had a chronic window frame leak
LINK: The Truck Camper had a chronic window frame leak
10/28/2017
Having tried several times and ways to caulk and repair
I decided to install an aluminum angle drip rail
To deflect rain water away from the window frame
I attached the drip rail with 1" stainless steel screws
I used DICOR caulk to adhere and seal it to the TC
Cleanup is easy with paper towels and paint thinner
  • Some window leaks are related to water that's coming from the roof area - even removing the window and reinstalling with butyl tape etc won't fix that. If you MacGver fix doesn't work consider having the rig pressure tested.
  • If you find it still leaks, remove the window frame and look at the joint where the extruded aluminum channel comes together. The back side of the union should be sealed with caulk but sometimes they dont do a very good job.
  • Did you ever pull the window and install new putty behind the frame? That is the only real way to repair a leaky window frame. Caulking along the edge is only a secondary seal that will fail.
  • From what I understand, you still have the leak, but you divert water from it?
    The proper way to seal the window is to use butyl tape under the frame.
    Caulk on the top is just short-living band-aid.
