emcvay
Jul 25, 2019Explorer III
Probably been asked a lot here, but what are you running on tire pressures? Seems like 80PSI in the back is right as it gives max cap but the fronts shouldn't need 80psi. I noticed at 75psi they climb over 80 in normal driving conditions so found that interesting but planning on leaving the fronts at 70 or 75 for now which seems close to Ford recommended settings and the back at 80 as above.
