mountainkowboy
Jul 28, 2019Explorer
Marcela wrote:
Don't be afraid to run the 80 psi on the back. I'd bet the weight transition when you make turns puts quite a load on the outside tires. Not all trucks sit in the driveway or on the scales.
I have to run red at 60 psi rears to be close to the recommended load-vs-weight of the tire and at 80 psi it rides horrible. I also ran my last set of rears at 80 psi and wore the centers out first....over inflated for the load. I run my fronts at 50 psi which is still high for the load.
