jimh406
Jul 28, 2019Explorer III
jaycocreek wrote:
I can see how a new AF 865 could easily overload a newer DRW..TC magazine list them right at 4400 pounds with AC..
But only #1Flyboy can verify his truck and capacities as listed on his truck...Not internet searches...
So, I guess you should stop trying ... I know it’s hard to admit the math, but let’s say the AF is 4400 dry ... not that you consider TCM to be a valid source if they don’t own one. :) That poster still has to add 2000 lbs to be 1500 over his GVWR with the numbers you found which are 1000 less than I found at the link I provided.
FWIW, Northwood says the 865 is 2641 dry. https://northwoodmfg.com/compare/4/65/arctic-fox-865/
In any case, not very likely that a DRW is 1500 over GVWR with that AF 865 or we aren’t getting the entire story even if this thread is way off track. ;)
