blt2ski
Jan 14, 2022Moderator
In mkirsh's and others example re 25 vs SW35 series. Reality is the 25 need to be lightened up literally gvwr wise! Make it a true beefed up 6 or 8 lug 15 series. Back to more online with the first one I bought in 81, most recent 2000, 6000-6800 grawr, front 4000-5000. The ability to get the smaller motors like the eco boost, smaller diesels that GM and Dodge have. Make it so the 25 does not compete per say with a SW35.
For me and my use, not towing much over 10-12k lbs, 3000-4000 lbs of payload. A truck in this axle wieght class will do that fine. I don't need or want the heavier frame etc that the current 25/35 series trucks wieght in at. I ran into a person at a fuel station. His crew cab short back d/a wieghed a 1000 lbs MORE than my 05 DW crew cab did!
Don't get me wrong, I've always felt the DW 35's were under speed when I was first buying trucks in the 80's .nothing between a 10k gvw and a 20k.
Now there is basically nothing between a 7500 and 11000 gvw truck. Maybe that truck is useless. But I'd bet there are lots of us in or have been in contraction, towing per DOT rules etc, that a beefed up version with the smaller motors better mpg empty etc would be better than the 15's we're driving. Grit and a few others probably fit this truck size as I do.
Marty
Marty
