iwski
May 09, 2014Explorer
BTPO1 wrote:
It sure would be nice to know where the added black wire is going since it is only powered when the heater is on. Maybe a 12V relay for an extra fan/blower motor?
I appreciate the responses. I did not have any responses as of last night so I went ahead and connected the white/black wires to the W1 terminal on the new thermostat. The furnace works. However, when I turn the temp down to cancel the call for heat, the furnace continues to blow the same hot air until the fan eventually cuts off. I sure thought I remembered this furnace cutting off the burner when the call for heat is cancelled and as the fan continues to run, the air would gradually cool down, then the fan would cut off. Isn't that normal?
The black wire is a bit of a mystery since everything appears to be stock on the camper (I'm the 3rd owner). I
44,066 PostsLatest Activity: Apr 10, 2026
