ShinerBock
Mar 16, 2018Explorer
Fordlover wrote:
I was very surprised when my friend's 2005 cummins with about 65K on the clock lost the injector tip about two years ago. He had to get a tow and a 5K injector job performed (this was parts and labor). A family friend's Ford 6.0 that had to be replaced big $$$. My uncles' 2006 cummins needed a new engine at 115K miles, more big $$$. A very close mechanic friend of mine tells me stories of Audi's, Porsche, BMW diesels that are requiring 8 to 12+k complete fuel system repairs at his shop. These aren't anecdotes to me, these are people I know who are honest with me.
I would tell your friend to get his fuel at a different location or at least drain his fuel water separator at regular intervals because injector blow out is mainly caused by water in the fuel. It could also be the fuel in the area you live in if you are actually having that many people with problems.
When I was at Cummins, we had a large quantity of fuel contamination failures happen in a certain area. It turned out that the local small fuel station that many of these people were getting their fuel from were not replacing their tank breathers allowing for water collect in the fuel through condensation and the drivers were not draining their fuel water separators like they should. It is hard to compress water so you can imagine what it does to an injector when you are trying to squeeze it out of it's tiny holes at 25,000 psi. Many 2010+ diesels have moved to having two fuel filters instead of one for this very reason.
However, if we are just pointing out worst case scenarios, I have plenty I can share about gas engines and even a few rods going through blocks due to timing chain failures or a block having to machined because the spark plug popped. I don't concentrate on worst case scenarios and would rather look at the good and bad as a whole to come to a conclusion.
Fordlover wrote:
As with most decisions, desire, need, and preference play a big part in the Diesel vs. Gas debate. Personally I love diesels, I just can't justify the cost for a truck that will spend a lot of time sitting in the driveway as a play toy, not making me money. And the idea that I will recoup some/most of my 8,500 bucks 12 to 15 years down the road doesn't make spending the 8,500 any more attractive to me on a depreciating asset. Truck buyers can do the same evaluation and come away with a different decision than mine.
Something is wrong if you feel the need you have to justify a diesel. You either want one for the pros or you don't due to the cons, simple as that. No need to only look at worst case scenarios in order to make yourself feel better about your truck buying decisions. There are pros and cons with everything and we can be here for years if you want to only point worst case scenario instances of both gas and diesel engines.
