Old-Biscuit wrote:
To me.totes are one of those aftermarket items that although for sale they are NOT needed, beneficial or worth the cost
YES I have one........it is almost like new/barely used and just takes up space in shed :B
I couldn't agree more. I did once years ago make the mistake of buying a 22 gal wheeled tote but ditched it after just one season when I realized just what a PITA it was to deal with. :M Since then I've instead been using
7 gal Aquatainers, one set for collecting fresh potable water and another set for off loading grey or even macerated black water with my FloJet Waste Macerator Pump, 'though with a 30 gal BW tank we're rarely in one place long enough that the BW tank needs off loading. For off loading grey water only one could alternately use an inexpensive 12 vdc pump
like this to transfer grey water into containers (of choice) already sitting in the back of the truck - no lifting, no dragging a heavy tote to the truck, no towing a wheeled tote at so-called "walking speed" to the dump station, no need to find a place to store that tote. Simply pumping GW into inexpensive, smaller, lighter, easy to handle containers already sitting in the back of the truck is to me such an obvious solution I'll never understand why so many still use these heavy, expensive, and annoying wheeled tote tanks. :h
