N_K's avatar
N_K
Thetford SmartTote2 LX usefullness
I have been looking at buying a Thetford SmartTote2 LX. Suggestions have been made in different forums to match the tank size with the size of the tanks being emptied. Thinking about this, I have a 38 gallon GW tank. I am concerned that a full 35 gal. cart would weigh quite a lot. I have switched to looking at an 18 gal. tank. These have a container level gauge that should help in not overfilling the container. Does anyone have experience using a container smaller than the tank it is emptying? Does it work? Do the features of this container especially the gauge work properly to keep the GW contained?
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    40 gal grey tank owner here. I have a 32 gal Barker 2 wheel tote and the long extendable handle gives enough leverage to move it around when full. It's towed by the truck anyway so I don't care much about the weight. If you go larger, go with a 4 wheel model. As to the small 18 gal totes, that wouldn't work for me.
    BTW, I bought the optional float thingy that goes in the top and found it kind of useless. I either threw it in my tool box or threw it away, don't remember. If you pay attention, you can easily shut the valve off before it overflows.
  • I have a 42 gallon tote that I use to dump my 40 gallon tanks. I dump once. I make one trip not 2 it takes 1/2 the time vs. using smaller totes.
    While a necessary evil dumping is a PIA chore. Why do it twice?
    I tow my tank to the dump station. I don't have to lift it or carry it. The tank has 4 wheels and I pull/maneuver it like a red wagon. I pull full tank 20' to my truck and tow it from there. I cannot lift 42 gallons of water but I can easily pull 42 gallons of water using a wagon/tote.
    Getting a tote as large as your tanks is good advice in my book.
  • I use a surplus 30-gallon plastic drum mounted in the truck bed. It's semi-transparent so you can see how full it's getting.
    My first gray water offload was into a 5-gallon bucket w/ pour spout lid. So yes you can use a smaller container if you want.
  • You are wise to consider weight. I see folks pullint their tanks to the dump station behind their rigs. But you still have to move it to the back of the truck. We have a 20 gallon and seldom use.
  • N&K wrote:
    suggestions have been made in different forums to match the tank size with the size of the tanks being emptied.
    That's not necessary. I use a 15 gallon with my 40 gallon tanks. Dump 2-3 times. Water is heavy.
    I don't know the specific reasons you're getting that advice.
