- ib516Explorer III can tell you I didn't photoshop it :) No idea.
The web forum it was on was a Dodge/Ram forum, so I suppose someone could do that, but the way it was described didn't sound like that.
I think it was due to the way it was loaded. - FordloverExplorer
Ron3rd wrote:
Hard to believe the frame could break or crack like that unless some other issue is going on or someone knows how to use Photoshop. I've been using PS for over 15 years and that would be easy to fake.
vid
It happens, put trucks in extreme situations, and failures will occur. - Ron3rdExplorer IIIHard to believe the frame could break or crack like that unless some other issue is going on or someone knows how to use Photoshop. I've been using PS for over 15 years and that would be easy to fake.
- Fast_MoparExplorer
FishOnOne wrote:
Wow... That tongue on that trailer doesn't look safe either.
Agree. The huge overhang requires a long tongue and tow bar, and that just looks like a recipe for disaster. - Bionic_ManExplorerI would like to hear the Paul Harvey version with the rest of the story.
I wonder how creative the for sale posting will be, calling out the shiny new frame. - Wow... That tongue on that trailer doesn't look safe either.
- jus2shyExplorerWow, they must had bee hauling lead to bend the frame like that. Superduty still uses a C-channel frame from the cab back, so it should be a fairly easy repair to the frame (Boxed sections are more difficult to work on). Having a longer hitch setup like that should take some weight off the tongue though.
- ib516Explorer III looked through the forum it was posted in again. The guy that posted the picture knows the owner personally. It was NOT from a wreck, just overloading. He said they actually just straightened the frame at a collision repair place on the frame machine and called it good :E. I don't know if they welded in any reinforcements or what.
Apparently, the TC is about 4500 empty. So the truck was probably overloaded. - jerem0621Explorer IIWow...just wow...that's a newer F350 based on the Dually fenders. I think 08 and up or 11 and up had that style of rear fender (not sure which).
There had to be way more to this story.
Of course 4000 lb truck camper plus 1000 lb tongue weight on a 50 inch lever certainly applied a lot of force to the frame. Even then I can't imagine a frame snapping.
Wonder if it was a rebuilt wreck with bad welds. Lol
Thanks! - carringbExplorerHmm did it get in a wreck? Can't see the front end. I can assure you that any tow truck on the road has had way more weight hanging off the back. Just YouTube "tow truck wheelie" if you don't believe that point :).
44,029 PostsLatest Activity: Jan 28, 2025
