~DJ~ wrote:
I found a 4.4 cu ft model real close to the dimensions of my gas fridge.
The specs say 24 watts per hour. That is 2 amps per hour? If so that is right in the ball park with my Engel 45 which used 2.5/hour.
My Engel picked up a bad vibration after 2 seasons. :M Won't go that route again. $$$$$
Really tired of these gas fridges that can't cut hot weather. 60 degree beer in 100 degree weather BLOWS!!!
Haven't had a chance to test again in 100 degree weather, though I have tested in upper 90s, and after super insulating the cabinet and adding custom ducting and a large number of specifically placed fans to improve air flow in the back on the fridge, it's stayed pretty much at 28-32 degrees all year round without having to adjust the settings up from 1 (out of 10 on electric) and 2 (out of 10) on gas.
