Jfet wrote:
I know we are supposed to stop talking about gas fridges in this thread, but I want to point out one more thing that might be the big problem people are having with them.
They are not efficient like compressor fridges.  In fact, they are probably 1/4 to 1/5 as efficient.  This means you REALLY need to make sure the ducting and airflow is there so the parts that are trying to cool the mixture are able to do so.  A compressor fridge you can practically shove into a closed closet and it will work, but an absorption fridge needs significant airflow over all of those fins.  If a bird has built a nest in them or if the rv manufacturer thought it would be cute to have a 1 inch opening for ventilation, you are going to have cooling problems.
A 12V computer fan, drawing about 50mA would work wonders for improving the airflow over those fins.  You could wire up a simple 8 bit microcontroller and thermister to have the fan come on when the ambient temperature around the fins is greater than 90 degrees or so.
Ok, last time I comment in this thread about gas fridges...back to the best compressor fridge for the OP.
I agree and understand this problem.  It is even worse in a pop up where the heat can not go u through the roof but has to be vectored out of a side vent.  The factory did put a fan in there to help suck out the heat.  Thanks.
