Huntindog
Sep 05, 2013Explorer
I have a third set mounted in front of the tires. I do use them for minor leveling adjustments. My frame is very stout, and up to the task. I see some that are like swiss cheese....Probably not a good idea with those types.
Like anything else, you gotta use your head.
I had the propane line issue as well. I made a custom spacer block to work around it. Later when I did my insulation upgrade, the line was in the way as well, so I ended up moving it over about 1 1/2". It was a lot easier than I thought it would be to do, and I wouldn't mess with the spacer block method again.
44,066 PostsLatest Activity: Mar 14, 2015
