Togger's avatar
Togger
This leak is UNBELEIVABLE
I have been trying to solve a most difficult rain leak since last summer. I have a Wildwood DLX park model with a domed rubber roof. When it rains I get water seepage on the back side of the trailer where the linoleum covered floor meets the sidewall (not in the slideouts).
The dealer has been out 3 times to try to solve it with no success. My wife and I have spent hours spraying the back side of the trailer with hoses and couldn't make it leak.
In desperation, we began spraying the front side of the trailer opposite the leaking side (NOT overspraying to the leaking side). After 40 minutes of spraying the front side wall/roof joint, water begins to leak on the opposite side of the trailer where the wall meets the floor. There is no sign of leakage in the ceiling or walls, just at the floor.
This seem unbeleivable. The water would have to do one of three things and none seem possible.
1. Cross above the ceiling and under the roof without making the ceiling or walls wet and run down inside the opposite wall to the floor.
2. Follow channels in the aluminum siding along the front side, around the back end, and 15 feet along the back side over the top of a slideout to where it ends up on the floor.
3. Run under the floor from the front side of the trailer to the back side, and then show up on top of the 3/4" tongue and groove plywood at the wall joint which would make it defy gravity by at least 3/4".
Has anyone ever seen a leak travel from one side to the other like this and have any idea how it could happen? I pulled the plastic cover strip off the gutter rail screw track and everything in the screwed joint looks normal. This is driving me absolutely insane.
