BobsYourUncle
Nov 17, 2013Nomad
Thought I was doing good in freezing temp - Oops! Not quite
So here I am north of Calgary Alberta, got the TT set up in the customers driveway close to where I am building a sunroom, all is good.
I know the mercury was going to plummet this weekend, and it did. I wrapped a heat tape around my dump pipes and gate valves - it seems to be working.
I am keeping the furnace a little higher than usual just to make sure all corners of the TT stay warm.
Ahhhh this is great!
(Bob hurts arm patting himself on the back......)
Make myself some dinner - time to do the dishes. Plug the sink, turn on the tap to begin water in the sink..... Hmmmm no cold water - huh?
Checked in the bathroom, which is first in line from the tank, tub, check, toilet, check, sink, check, all have water, nothing at the kitchen sink, the end of the line.
Dangit, thought I had it all figured out! I have a freezeup between the bathroom and kitchen.
So I pull the lower drawers out and see the water lines run right past the wheelhouse enclosure, which is made of single layer plastic and no insulation on it! Turkeys! They shoulda insulated the wheelhouse thingys! There is a solid layer of ice all over the plastic housing and the cold water pipe which is right against it, has frozen.
OK, leave the drawers out for the trip to get some heat in there. Grab my little space heater, park it on top of a case of Kraft Dinner my wife insisted I bring. (as if I'm going to eat a case of that stuff!!):E
I'm going to have condensation running all over the floor but hey! I can mop it up - better that than frozen pipes!
Outside temperature is 9.7F right now according to my remote sensor I keep on the hitch.
And I thought I had it all figured out! Sheesh! :B
