PUCampin
Jul 18, 2016Explorer
Actually these numbers look good. The tongue weight is with the bars hooked up, so actual tongue weight will be more, probably around 12 percent, which is fine. We also know the weight distribution is maybe even too tight. The OP is actually ADDING 22lbs to the front axle vs the truck by itself. The manufacture recommendation is to return close to the original front axle weight. Weight is removed when the trailer is hooked up, the weight distribution puts some of that weight back. In this case it is all put back and then some!
44,070 PostsLatest Activity: Jul 21, 2026
