- gmckenzieExplorerI've got a hard-wired one (PI). I had a surge guard that plugged in, but I found it a pain and would often not use it. Likely at the worst times (rushing setting up in the rain etc.) Plus I camped at a couple of sites where I'd have to lay it on the ground to plug in.
Now with the hardwired one, there is no doubt I'm using it. - LynnmorExplorer II
hawkeye-08 wrote:
Its on my wish list, in the mean time, I have a monitor (displays voltage and checks for miswired) that I use to check before plugging in. I then plug it into the outlet near the sink so I can easily see it so if voltage drops too low I can turn off AC. It is not automatic, but it is what I have until I can budget the EMS.
If the voltage drops too low, then an autoformer might keep you going. I use one because I have seen low voltage many times. - Its on my wish list, in the mean time, I have a monitor (displays voltage and checks for miswired) that I use to check before plugging in. I then plug it into the outlet near the sink so I can easily see it so if voltage drops too low I can turn off AC. It is not automatic, but it is what I have until I can budget the EMS.
- BobboExplorer III
CA Traveler wrote:
In 14 years I've never had a known "surge" error with the RV. It might help but in my opinion you're likely waisting your dollars.
I'm glad you put the qualifier "known" in your statement. In 13 years (all but the first 6 months with the EMS-HW30C) I have had no "known" surges either. However, it has disconnected me from power several times for low voltage, and once for high voltage. Surges are not the only problem. I still call this cheap insurance. - 2012ColemanExplorer II
bpounds wrote:
I didn't have one for a long time, but decided to get one after reading about them - and only decided that it was a must have item after it did it's job at two different CG's. I would not want a TT with a pre-wired EMS - it would be bottom of the line like most of the stuff they install. And an electrical system is just as important on low end units as it is on high end units. I personally don't look to the RV industry to tell me anything - they just want my money. Heck you can buy slide out supports from Camping World. I'd rather listen to the opinions of people with actual experience.2012Coleman wrote:
bpounds wrote:
I think you got your percentages turned around. The progressive Industries EMS is so much more that a surge protector. I've been helped by mine more than once for stuff besides electrical surges. I won't go into specifics for all you 10 percenters...
Folks who have them, have already convinced themselves that you must get one.
Meanwhile, by my estimate the other 90% if us are getting along just fine without one.
Okay, your percentages are just as good as mine, since I just made up a number. I don't think we will find an RV industry survey to tell us the EMS ratio. Just observations is all I have, and I rarely speak with anyone who has installed one. My point above was, those who have decided that they are a must-have item, jump on threads like this. Those who don't, tend to not bother discussing something they don't find important.
Another reference point would be how rarely they are offered on new RV units as primary options. If typical folks felt strongly about that insurance, I'm sure the manufacturers would jump at the opportunity to offer an upgrade.
I'm sure an EMS is much more popular added to higher end rigs. There is a lot more to lose, so insurance becomes more desirable. An EMS is simply that - insurance. Some folks put more faith in it than others. - CA_TravelerExplorer III
rbpru wrote:
My question is how many joules are needed?
I suspect if lightning strikes near enough to put an impulse on the line, your surge is toast with the rest of your gear.
Likely never enough joules for lightning but might be OK for smaller electrical transients.
However, crossed wiring is a problem I have run into.
I've always carried a 50/30 adapter, 30/20 adapter and a common household tester which does the job. Not to likely a miswired pedestal when initially tested will change later... - CA_TravelerExplorer III
I will get this: Progressive Industries SSP-50XL I can't afford a full flegged flagship surge protector so I'm hoping this will do. - Matt1221ExplorerI will get this: Progressive Industries SSP-50XL I can't afford a full flegged flagship surge protector so I'm hoping this will do.
- rbpruExplorer IIMy question is how many joules are needed?
However, crossed wiring is a problem I have run into. - spoon059Explorer IIIWe had a campground with low voltage a couple years ago. We have an EMS that warned us and shut down power. Without it, we probably wouldn't have known and possibly fried our AC compressor. That was worth the price of the unit, right there.
44,071 PostsLatest Activity: Aug 16, 2026
