I owned a 2004 28 Safari for 4 years. Towed over 40k miles coast to coast. Loved way it looked, towed smoothly, but>>
Sway, side winds were an issue, despite Reese cams etc.
Clear coat was peeling off. Huge issue.
Corrosion, a real problem and Alcoa should be ashamed.
Soft floors, moisture builds up and a mess. insulation , frames rusting. Cant get at it to fix.
Leaks.
I now own a Camplite 16 db. Love it so much I want a 21, need to sell the 16 first. These things are built like they all should, bit crude but they are getting warmer looking inside and all Azdel. The cabinet frames look industrial, all welded. No wood anywhere.
