jerem0621's avatar
jerem0621
Explorer II
Aug 06, 2013
Throw away trailers??
Are conventional trailers consider "throw away" trailers? Meaning 10 years or so of useful life?
Case in point... I like Airstreams and one day I will probably own one. I often go to the AIR forums and try to pick up a few tips and learn a little from them. I keep seeing a theme from Airstream owners that they refer to box trailers as throw away trailers. I kind wonder about this, and if its true??
My box trailer is nearly 20 years old now and is a little long in the tooth in some areas. I will have to repair some wood damage and other various little things. However, with maintenance, I really don't see why a box trailer cant last 20-30-40 years.
I mean, there are users on here with box trailers dating to the 70's and 80's regularly and some with even older trailers.
Maybe it's an emotional thing? People love to pull an airstream out of the weeds and put 10-20k in it restoring it and then talk about longevity.
Maybe I just don't understand the concept of a throw away trailer.
Thanks!
Jeremiah
  • I think it is about how well people take care of their trailers. Says more about being a throw away society than it does the trailers being throw away. If people did the maintenance on their trailers like they are supposed to, I think most trailers would last 20 years or more. Most people I talk to at best check their roofs yearly, wash and wax their trailer once a year maybe, fix it when it's broken but really don't give it a thorough inspection on all parts and appliances.
    I walk the roof every spring, every fall, seal or fix anything that looks like it might begin to be a problem. Wash the trailer after every trip, wax it twice a year (spring and fall), spray the stab jacks every other trip or so with silicone lub, check the water heater, furnace, frig vents a couple times a year and a general walk around inspection checking lights,windows, trim and the sealant around them. I'm hoping to get 15-20 years out of mine or at a minimum, get top dollar for it when I trade up once I retire.
  • Maintenance is the key. Some people will do nothing to a RV and it's trashed in 5 years. Others that take care of what they have get 20 years or more out of them.
    Jeremiah
    It can.
    But I think more aluminum-sided stick-built trailers (not just Airstreams) will survive that long than will those sided with the various composite-sandwich type skins.
    All- molded fiberglass trailers like that used for boats are also noted for longevity (my own is a '78). But that's an entirely different type of construction from that used for most RV trailers.
