- FarmerjonExplorerThat's what we have been finding. The listings say white but the pictures don't show white. We will be making phone calls Monday to see what's available. Those part #s should help.
I'm sorry I didn't mean a set of 2, I meant I have 2 sets of 4 turnbuckles.:)
Thanks - AnEv942NomadNot sure- about white or if a set of 2 can be had. You might contact Torklift. Their site shows only black aluminum bodies now (with same part number as old polished stainless).
Be finding some still on the shelf somewhere...
Few references for older stock still out there- if available unknown
Torklift S9525 white
Torklift S9528 polished SST (same p/n as new al. black)
http://www.americanrvcompany.com/Torklift-S9525-Fastgun-Derringer-Retrofit-Stainless-White-4-Pack lists the older white (but pic is polished) might call to see if they have them. - FarmerjonExplorerAnEv942
Thanks, If we understand the listings we are finding The Derringers seem to be available in 3 colors and we are trying to find Powder coated white . - AnEv942NomadYa if you have the turnbuckles the derringers pretty flexible. Its either just cutting off turnbuckle eye and threading into derringer (you may have to thread end of turnbuckle rod), replace with all thread or use included eye, though you may still need to cut rod depending on length. The eye simplest but you end up with separate pieces.
http://www.torklift.com/index.php/products/turnbuckles/derringer-handles - FarmerjonExplorerThanks for replying.
That is good as we already have 2 sets of spring loaded turnbuckles. We just need to shop for a set of Derringers.
Jon - cewillisExplorerI asked Torklift a similar question a few years ago. Here's what they said:
"Thanks for writing. Yes, you can use the Derringer handle with Basic Spring Loads and chain.
You are good to go."
