billtex
Nov 06, 2020Explorer II
bigfootford wrote:
Hay Rob, guess you did not look at my BF to realize my porch is what you need. Mine is 18" but you could do it less. Simple bracing from the rear jack brackets.
Here is the build thread showing what Reddog1 and I did years ago. I did get the Glow Steps from Torquelift. A big difference in rigidity.
https://www.rv.net/forum/Index.cfm/fuseaction/thread/tid/25135064.cfm
Jim
Our solution is similar except I was able to mount the Glo-steps directly under the door frame. Note; I retained the OE two step and I leave it in place (folded up when under way). In the event we unload the TC we can use the OE setup. This setup works well for us and gives us a lot of flexibility depending on slope, etc
Edit; Let’s see if this works
Bill
