2001400ex wrote:
Cummins12V98 wrote:
2001400ex wrote:
It'll be interesting to see what it looks like when they put all three up against each other. Historically GM has been able to put the power to the ground better than the other two. Most of the tests throughout the years, they are the first up the hill on pulling tests. The last test between just ram and GM, they were basically equal up the Ike pulling a load but the GM was faster unloaded.
UH the RAM was a DRW and GM a lighter SRW. GM should have walked away.
They both were basically at the speed limit the entire time. You can't walk away when you are at the speed limit on that test.
Yep, unless they load them down enough to slow them down, it just depends on wether a car pull n front of them and shaves a few seconds off or not.
