chrispitude
Feb 10, 2018Explorer
falconbrother wrote:
We tow with a 00 Burb 4x4, 5.3..27 feel, 5800 pounds. It does fine. It took me a couple of trips to figure the thing out. I added Sumo SuperSprings to the rear. I keep mine out of overdrive and run around 65 MPH. When I'm pulling a steep mountain I don't let it lug, I'll pull it down to 2nd gear and let it rev (55MPH+-). It pulls my trailer just fine. I use towhaul most of the time but, in stop and go traffic I take it out of towhaul. I doesn't need the higher RPM shift point to be comfortable in city traffic. The 4l60e isn't an issue, that I have noticed. I do a drain and fill on mine at every oil change to keep fresh Dex6 in it. And, when I'm towing I take it easy. Never had any issues with my transmission, at least not yet. I bought a cooler and pulled the grill off to install it. Then I saw the factory installed extra cooler and didn't install the aftermarket cooler. It's still in the box in my garage. I haven't decided if I'll install it. Frankly, I don't think I need it. I pulled my transmission pan a few months ago and replaced the filter. I then ground down the stock drain plug and welded an 11/16 nut to it, cause that's the fist one I grabbed out of the spare hardware bin. So, now the plug comes off easy so, I can do a drain and fill in a couple of minutes.
There's been exhaustive discussion on this forum about transmission coolers. You can look it up. If you have the factory tow package and keep your transmission serviced...and don't try to kill it while towing it should be fine. If I were pulling up mountains a lot I'd add the cooler. Most of our trips are beach trips. We went to the mountains once last year and I just pull it down in second so there's no hunting for gears. When I get home from a trip like that I pull the drain plug and replace 4.5 quarts + -. People will trash the Suburbans, Yukons but, I love mine.
My wife does dog shows so, we need a vehicle that has climate control in a large area and will tow an RV. And, I like the 4x4. I was looking for a Ford when I found the burb. It was such a good deal I bought it against my better judgement. It has turned out to be a great vehicle.
Wow, lots of great information here! (And thanks for the thumbs-up from intheburbs too!)
All our towing will be east of the Rockies, so no huge grades. I don't know if all the trucks have a transmission temperature gauge, but this one does and that should be useful. I've been meaning to see if I have a transmission cooler. And cool trick with the transmission drain plug, I might do that too.
The truck was serviced with Amsoil fluids front to back, including the differentials. We used the GM fluid in the transfer case, just to be safe. All suspension joints and bushings have been replaced. The drivetrain's a bit noisy when cruising at highway speed, not sure if that's the nature of the Denali AWD system or not.
I'm wondering whether the rear air suspension will be a strong or weak spot of this setup. The original factory setup had some problems, including a leak that caused the compressor to cycle. The Arnott compressor and shocks have been solid so far - nice and tight, no compressor cycling - but I'm wondering how the system will react once I hitch up. It'll make calibrating the weight distribution pretty interesting, for sure!
