Find a floor plan you like that will work for you. Check the trailer weights to see if they fall with-in the towing capacities of your tow vehicle. If they don't, will you buy a vehicle, that can pull it SAFELY. If you will not go up on a tow vehicle then look for a trailer your vehicle can tow. Do not believe salesmen that tell you, you can pull anything with your tow vehicle. I am a stickler for staying within the towing limits of my TV. I don't know a lot about the units you mentioned so can't give you any help there. Hope this gives you a little help in your selection.
