uconn_jack
Jun 02, 2023Explorer
Tire Advice
Hi, I recently had a blowout on my 2009 Skyline Layton 2970 TT (8,800 GVWR). Bought it used late last year, great shape, with Goodyears (including spare) on it that also looked in good shape and ...
Huntindog wrote:What TPMS system do you use?aftermath wrote:Actually the opposite is true. Some claims are that STs have thicker cords, but fewer layers in order to run cooler. The same is stated for the shallower tread depth.There has always been a lot of "marketing" claims for ST tires. That is just some of them. It is not in the test...But anyone that has done a hands on of the two types of tires can tell you that the LT has stronger sidewalls.
I think the "scuffing" comment has to do with the design of the sidewalls not the tread. Because of the lateral pressure put on trailer tires as they are moved into parking situations the ST tire has a stronger sidewall than regular tires.
If you look carefully at the ST construction claims you will see that they have one thing in common. They all make the tire cheaper to manufacture.
