Huntindog
Jul 10, 2015Explorer
The goodyear wrangler LT tires that you have will work. They wouldn't be my first choice in an LT tire, but they are better than any P or ST tire out there.
If it was mine I would get a couple of LT tires a little better suited for TT use, such as the wrangler HT that was mentioned. TT tires tread doesn't have to match, so it will work fine, and be the most cost effective option at this point.
When it is time to replace all of the tires next time, you can get ones that match... In the meantime, do some research on tires that are used on TTS. Pay particular attention to the govt. required testing standards for ST tires vs. LT tires. Then you will see why many of us use and recommend LT tires.
44,066 PostsLatest Activity: Oct 04, 2013
