I just switched from Carlisle ST 225/75R15C with a 50 PSI max to Maxxis ST 225/75R15D 65 PSI max. What PSI would you run these load D tires at. MY GVWR is 9015lbs.
Community Alumni
Not applicable
Jun 06, 2014
65 psi cold provided your rims are rated for at least 75 psi max. Typically during very hot days traveling at interstate speeds they will gain up to 10%.
