Cummins12V98
Jul 13, 2014Explorer III
As I have said here before. Contact GY Tech Support for what they say. I did when going from GY E to GY G. They said to use the chart on RV for STOCK RATED TIRES. But if you are up rating the tires use the inflation chart for your new tires and add 5psi. For example my RV said 80psi and my load need that psi, surprise surprise! Now with the G tires the load still needed 80psi but by adding 5 psi I was at the proper tire inflation for the tire.
They said they defer to RV label when stock tires are replaced with stock but the charts are there for a reason. They also said too much air as in 110psi for my load will give a more harsh ride along with less stopping traction.
I used GY inflation method for 5 years and a lot of miles with perfect tire wear and never a problem.
44,056 PostsLatest Activity: Nov 19, 2013
