NC_Hauler
Jul 13, 2014Explorer
blt2ski wrote:
An E rated tire of the same size as a D rated tire, will carry the same load at the same pressure up to the max of the D rated tire. The E rated tire has the ability to carry a higher pressure, hence a heavier load.
A tire pressure load chart works, I use the chalk method. Ie put some tire chalk on the tread, drive down the road, if all of the chalk goes away in a 100 yds or so, you either have the correct pressure, or too little. If a partial goes away, ie the middle only, you have too much psi. You can see the same effect after going thru a puddle and stopping a few yds later, or if the middle has dust, the outer does not.....
Not sure there is truly a right or wrong way per say. Other than, not fun to see the middles wear out of the tread before the outer. Then you know you had too much psi, and wore out the tire too soon!
marty
Marty..WAYYYY to much work and I'm not lazy...Pretty doggone sure from what I've gleaned from Michelin, Continental/General and Goodyear, that running at sidewall max recommended psi will NOT cause issues with the tire...IF used as an E or G rated tire in replacement of an E or G rated tire..... I've never seen the middle of my tire wear abnormally....
Again, if one has the time and equipment to weigh each tire, have at it, but I'm not hooking up and running back and forth over something to check tire pattern AND I don't have access close by, or the time, to find a place where I can get each tire weighed....I'll go by manufacturers recommendations and again, the GY G614's on my 5er now, run at 110 psi and look as good as they did the day they were put on my 5er in Oct. of 2010....
44,056 PostsLatest Activity: Nov 19, 2013
