Rich1961
Jul 13, 2014Explorer
Cummins12V98 wrote:
Jim your HR came with E tires correct? They recommended max pressure at 80 psi correct? The G tire Carries the same load as the E at the same pressure. So to say HR wants you to run 110 psi on your G tires does not sound right.
Run what you want it's up to you but talk to GY tech they will tell you that you can use the charts for proper inflation based on load when up sizing the load rating.
Shouldn't the wheels be rated for the higher pressure also?
Rich
44,056 PostsLatest Activity: Nov 19, 2013
