NC_Hauler
Jul 13, 2014Explorer
Cummins12V98 wrote:NC Hauler wrote:Cummins12V98 wrote:
Jim your HR came with E tires correct? They recommended max pressure at 80 psi correct? The G tire Carries the same load as the E at the same pressure. So to say HR wants you to run 110 psi on your G tires does not sound right.
Run what you want it's up to you but talk to GY tech they will tell you that you can use the charts for proper inflation based on load when up sizing the load rating.
My 5er has a GVW of 16,950 with 7,000# rated axles...My 5er came with GY G614's..... 110 psi....that's what is listed on the placard on the 5er and that is also what Goodyear recommended.
OK. I saw something about you having E tires must have been on another RV.
Years ago when I owned a Coachmen Somerset (an 04'), it had OEM "E" rated tires.. Can't remember the names, but 5er had a GVW of 14,000# with 6,000# axles. (pin weight was 2400#, (loaded to a little over 13,000#). I removed the tires and put Michelin XPS RIBS on THAT 5er...5er I purchased brand new in 07' (one in my sig), came with GY G614 tires.
44,056 PostsLatest Activity: Nov 19, 2013
