Cummins12V98
Jul 15, 2014Explorer III
wintersun wrote:
Big mistake to go by the tire manufacturers' charts. Use the vehicle manufacturer's recommended pressure as that is what they have designed the suspension for and it is vehicle specific.
Use the charts and the tires will be underinflated and tread life will be shortened and handling will be worse.
Really?
The vehicle unloaded guide will get you per mature tire wear because they want a soft ride. Loaded the over compensate on the rear tires because they have no idea what load you will be adding.
A little common sense and tire weight/inflation charts will give you long tire life. Do you get over 100k from a set of pickup tires? I do.
44,056 PostsLatest Activity: Nov 19, 2013
