Need some help Please. Want to put new tires on my 25' kz trailer. Some stores say Radial, While some say Bias tires for trailers. The one I took off were only 2-ply tires. and thinking would like 7...
They don't MAKE a 7 ply ST radial tire but you can get a 6 ply RATED (they're radials so really don't HAVE plys) which is a load range C tire. I would ONLY recommend this if you buy a Maxxis tire. Nearly all others are "born to blow up" For what it's worth, if you've been running a passenger tire on a duel axle trailer you've ALREADY used up most of the luck you have coming :) Good luck / Skip
