Need some help Please. Want to put new tires on my 25' kz trailer. Some stores say Radial, While some say Bias tires for trailers. The one I took off were only 2-ply tires. and thinking would like 7...
Tires will heat up at speed and increase in pressure. All is normal as the tire makers take all this into consideration when the tire was designed. I've seen my 80 psi E tires on my equipment trailers when carrying loads go to 92-94 psi on a hot 100+ degree day and interstate speeds after a long run.
