BurbMan
Aug 14, 2013Explorer III
azdryheat wrote:
Airbags are not the same as a tire. The entire airbag is compressed from weight above while a tire is only compressed on the lower portion of the tire. That's why a tire only goes flat on the bottom, lol.
Correct answer here! Check your tires when empty and then recheck them with the truck fully loaded (assuming you haven't driven on them and ambient temp is the same) and the pressure will be exactly the same.
The airbag is getting squeezed as the suspension is loaded, and less volume = more pressure. So not surprised 10 psi empty becomes 20 psi loaded. The size of the tire is not changing, therefore it's pressure can not change unless the temp changes.
Go tell your co-woker ha-ha nice try but you ain't falling that old trick. Then ask him if he has two 10's for a five.....
