nickthehunter
Feb 16, 2017Nomad III
Those tires are probably rated at somewhere around 3200 lbs at 80psi (or 12,800 lbs total for 4). At 55 psi they are probably still up around 10,000 lbs. total, which is still more than your GVWR. In any event, you should be able to get the inflation chart online for you particular tire and use that as a starting point. Weighing it would be more exact, but even if you use your GVWR plus a cushion that should be adequate. I run mine at 65 psi all day every day.
44,056 PostsLatest Activity: Dec 27, 2025
