BMW442ExplorerNov 05, 2014Tire Pressure?Gearing up for our first trip. Do you usually top off the tires after loading camper? Set them at or just under max cold psi?
jimh406Explorer IIINov 05, 2014I set my tire pressure before loading the camper at the pressure I expect to run. That's not usually the max pressure. I think the only time I ran max pressure was when I had Es on a SRW.deltabravoNomadNov 05, 2014I put them at the PSI that is indicated on the door jamb sticker, which for my DRW 09 Silverado is 66 PSI front and 60 PSI rear, stock tire size.RWDIIIExplorerNov 05, 2014Depends on load and tire rating.I put this info in signature line.Would be nice to have some info!
