When you get new tires, give the suspension a good looking over. When I had a blowout on the TT, I found that that the cheap OEM shackle bushings had worn through. On the curb side (where I had the blowout) the equalizer that goes between the springs was frozen with rust and couldn't pivot. So instead of equalizing the load between the tires, the front tire was overloaded and is likely what caused it to blow.
Now is a good time to replace the shackle bushings (
Nev-R-Fail work well) and upgrade the equalizers to something like the
EZ Flex.
Here is
one thread on the topic.
Also be sure to have those new tires balanced!!
