tcc11tcc
Jun 19, 2013Explorer
Tire question
I just got new tires and they state inflate to 44 PSI. Why did the dealer only put 32 PSI in them? I believe that is what it says to do on the door but these are different tires than what came on th...
tcc11tcc wrote:
I suppose this means P rated, P275/60R20
So you fill back ones to 40ish when towing and leave front at 32?
For some reason I thought if you didn't have the tires inflated to where they were suppose to be, they wouldn't wear correctly?
I always inflate my boat and campers tires to what they list as Max PSI because I was told to do that.
Not very mechanical....can you tell :)
