BenK
May 18, 2020Explorer
Jeremiah....mine’s a K3500, big block 7.4L....
Tongue n cheek...cuz ordered it with the F60 option. IIRC $67 bucks for the snow plow prep option. Begets 1 ton front torsion bars and GMT400, 8.6K lb GVWR Suburbans have the same AAM rear axle as the 1 ton daully...even the same drum/shoe’s...except for the rear cylinders, which I’ve changed out (larger dia bore) and the MC (larger bore for the rear lines)
When you start looking, suggest checking the glove box door label for the F60 option, which begets the bigger drums and shoes
Good hearing from you
