I am biased toward Michelin tires. I have never had anything but good luck with them. Moving on though, with the taller tires there are two things to look at. One is that, especially if the truck has a lift also, it will get the truck to sit taller in comparison the the ride height for the trailer. It is especially noticeable with a fifth wheel, possibly requiring the fifth wheel ride height to be raised slightly. I just changed to a newer truck that sits slightly taller and it has changed the way the tires on my trailer wear. The second item I see is that the taller tire will change your final drive ratio, but as your trailer probably isn't anywhere near your capacity the difference shouldn't be a big problem.
