JJBirish is wrong on every point made in his particular post above.
LowSuv has only promoted the specific Goodyear Cargo G26 as a remedy to the lower quality ST tires . 2470 # on the LT scale , 106 mph rating , and tire weight about 4 pounds more than the Maxxis .
It is not logical that LowSuv supports the ST Marathon because the Cargo G26 is such a good tire . JJ makes that conclusion by himself .
The logical evidence that Maxxis tires are a lower quality is supported completely and repeatedly by using the " view posts " feature readily available under the poster's icon .
JJBirish is not a motorhead and proud of it .
The advantages of being a motorhead at tire selection time are obvious .
JJ has offered no empirical evidence that Maxxis ST tires are somehow magically superior when their passenger car tires score in the lowest 25 % .
LowSuv has repeatedly offered specific tire choices that fit the OP's needs when the OP indicates the size tire currently in use .
JJ enters into character assassination frequently .
LowSuv has been the point of those posts several times .
The " view posts " feature is available to support each of my assertations .
