Lowsuv wrote:
Here is a quiz :
Which tire is likely to be a better tire ?
Tire One
225/75R15 load range D
diameter = 28.3" x 8.8 " section width
Max speed rating 65 mph
Tire weight = 31 #
Made in China
Cost is $ 89 each
OR Tire Two
The 225/70R15 Load Range D
diameter = 27.4" x 9 " section width
Max speed rating 106 mph
tire weight is 33 #
Made in Germany
Cost is $ 156 each
Both tires are made by the same manufacturer .
Both tires use the same wheel and fit in the same space under the trailer .
Oo, oo, Mr Cotter, pick me. I know the answer to this one!
The 225/75R15, because it has more natural load carrying capacity - assuming both tires are made with exactly the same materials in exactly the same way.
But I think there are some missing pieces of information. First is the letters in front of or behind the tire size that tell the intended service of the tire. There is also the issue of load carrying capacity - which is kind of dependent on those letters.
And then there is the bit of information we will never know the answer to - and that is what is the ACTUAL materials used in the making of the tire. Even though they may be made in different places, that doesn't mean there is a difference in quality, nor design. On the other hand, they could be completely different. We just don't know.
