AlmostAnOldGuy
Jul 27, 2019Explorer
I suspect the reason your front tires have less tread then the back is because unloaded you have more weight on the front axel than on the rear. This is even more so if you are running a diesel.
Also, you and I live in some country that can get wet. If I am plowing through some water on the road I want the front tires which do most of the braking and steering to shed water well.
So if you think these apply to you I would rotate.
Take it easy,
Stu
Take it easy,
Stu
44,066 PostsLatest Activity: Apr 16, 2026
